> ## Documentation Index
> Fetch the complete documentation index at: https://superwhisper.com/docs/llms.txt
> Use this file to discover all available pages before exploring further.
# Wrong Microphone or System Audio Not Captured
> Fix Superwhisper using the wrong microphone, AirPods audio problems, and system-audio recordings that come out empty.
## Superwhisper uses the wrong microphone
The active input device shows in the **top-right of every settings pane**. Click it to switch:
<img style={{ borderRadius: '0.5rem' }} src="https://mintcdn.com/superwhisper/do-XBuvOUgvVmZf6/images/screens/mac/input-device-dropdown.png?fit=max&auto=format&n=do-XBuvOUgvVmZf6&q=85&s=31978731705ddafb96422f794ae2715a" alt="Superwhisper input device selector open from the top-right of the settings window" width="1760" height="2060" data-path="images/screens/mac/input-device-dropdown.png" />
* **Use system default** follows whatever macOS or Windows has selected, which changes when a Bluetooth headset connects. If Superwhisper switches microphones on its own, the system default changed underneath it.
* **Pin a specific microphone** to stop the switching. The star marks your preferred device.
## AirPods and Bluetooth headsets sound worse
When a Bluetooth headset's microphone is active, the audio quality drops. This is a Bluetooth limitation, not a Superwhisper setting, and it reduces transcription accuracy. For best results, pin your **built-in microphone** as the input and keep listening through the headset.
## System audio recordings come out empty or silent
System audio (recording what your computer plays, for meetings) is a per-mode feature:
1. **Enable it in the mode**: edit the mode and turn on **Record from System Audio**. See [audio options](/docs/modes/modes#advanced-settings)
2. **A still waveform is normal**: the waveform doesn't move during system-audio capture. Check [History](/docs/get-started/history) to confirm the audio recorded
3. **Check your org policy**: on an Enterprise license, your organization can disable system audio recording org-wide. If the option is missing, ask your admin
4. **Bluetooth output can complicate capture**: if a meeting recorded silent while using Bluetooth audio, retry with built-in speakers or wired headphones and email [support@superwhisper.com](mailto:support@superwhisper.com) with the device model
## Notifications and other apps in the recording
System-audio capture records everything the computer plays, including notification sounds. Mute notifications during meetings you record, or record microphone-only modes when you don't need the other side.
