> ## Documentation Index
> Fetch the complete documentation index at: https://superwhisper.com/docs/llms.txt
> Use this file to discover all available pages before exploring further.
# Shortcuts Not Working or Misfiring
> Fix Superwhisper keyboard shortcuts that don't trigger, trigger the wrong mode, or stay bound after you reassign them.
## The shortcut triggers the wrong mode
Superwhisper has two kinds of shortcuts, and mixing them up is the most common cause:
* **Global shortcuts** (Settings → Configuration): Toggle Recording, Push-to-Talk, Cancel. They record with whatever mode is active.
* **Per-mode shortcuts**: each mode has its own **Keyboard shortcut** field in the mode editor that starts a recording in that specific mode.
If a key starts the wrong mode, check whether it's assigned in both places. The per-mode assignment takes priority.
## Nothing happens when I press the shortcut
1. **Another app owns the key**: global shortcuts lose to system and app shortcuts. Test an uncommon combination to confirm, then pick a key no other app uses.
2. **Check the recording window setting**: if the recording window is set to **None**, recording still works but shows nothing on screen. Dictate a line and check [History](/docs/get-started/history).
3. **Single modifier keys**: Left Command, Right Command, and Fn work on their own for Toggle Recording, but some keyboards send Fn to the system instead of apps. Test with a regular combination.
4. **Restart Superwhisper**: if the shortcut works after a restart, [update the app](/docs/get-started/essential-settings#application-behavior). Stuck registrations are fixed in updates.
## The old shortcut still fires after I changed it
Reassign the shortcut in **Settings → Configuration**, then restart Superwhisper. If the old binding still fires after a restart, email [support@superwhisper.com](mailto:support@superwhisper.com) with your app version and the stuck key.
## Push-to-talk behavior
* **Shared key**: Push-to-Talk can share a key with Toggle Recording. Press and hold to record push-to-talk style; tap to toggle.
* **Mouse buttons**: a quick click toggles, and press-and-hold acts as push-to-talk. Some mice can't detect sustained holds; if hold-to-record releases at random, use a keyboard key instead.
