This page applies only to Superwhisper on iOS. macOS and Windows are not affected.
The fix
After you tap the Superwhisper keyboard button to start dictation, swipe back to your app yourself. iOS 26.4 no longer lets third-party keyboards return you to the previous app automatically.What changed
Apple’s iOS 26.4 update changed how third-party keyboards work. Superwhisper used to return you to your app after you started dictation. That behavior is no longer available. Your modes still work as before. This includes Message, Mail, Note, and any custom modes.FAQ
Do these changes affect macOS or Windows?
No. These are iOS-specific platform changes. Features like auto-activation rules continue to work on macOS and Windows.
I'm seeing unexpected behavior beyond what's described here
Email support@superwhisper.com with your iPhone model, iOS version, and Superwhisper version. A short screen recording helps if you can include one.
Can I report this to Apple?
Yes, and we encourage it. The more people report the issue, the more likely Apple is to address it. File feedback in Apple’s Feedback Assistant. Consider referencing feedback ID FB22247647, which tracks the underlying
hostApplicationBundleID bug affecting third-party keyboards.
